Mosaic x5 ardupilot
does any one have success in connecting septentrio mosaic x5 with ardupilot? i have connected the module and removed the ublox primary gps. changed settings on mosaic x5 to output nmea data at 100ms and changed the same in mission planner.
in Alt hold my quad is flying okay but in POS hold it tries to topple itself. i cant understand the reason where am i making mistake. i have mainly followed this link except mosaic H also gives Heading which mosaic x5 doesnot so the compass is left enabled in my case. https://www.ardusimple.com/ardupilot-simplertk3b-heading-configuration/
if anyone has interfaced mosaic x5 successfully kindly share the parameters that needs to be changed.
thank you
Are you using ArduCopter 4.4.3 or newer? You should.
We have good succes with Holybro Mosaic-H RTK unit. you need to configure the streams to the various Uart poprt using the web page or RxControl. there are some good youtube videos from Septentrio that explanin what is required for SBF format to ardupilot.
The Mosaic X5 cxomes in two variants -the x5 with single antenna and the -H with dual antenna for heading. The septentrio is an awesoime chipset with multiple generatios of development (blows the ublox out of the water)
