I raised this issue in Copter, but Mission Planner should take care of this.
Here’s the post in Copter:
all waypoints sent to the drone are acknowledged on upload.
You know ‘Write WPs’, ‘Clear Mission’, ‘Read WPs’ command ?
so you’re saying it’s copter’s fault? adding an automatic “read wps” after “write wps” would catch upload errors, just loop until all match
my question is more around show me something that’s failing, and I will work to resolve it.
if you need to verify then I would always suggest using the read wp’s
When only 12 of 67 waypoints loads into pixhawk, I can’t think of a bigger failure. What exactly do you mean?
