Hello guys, I have just recently encountered a strange incidence with Mission Planner 1.3.70 (build 1.3.7277.34800).
I managed to setup a Joystick (simulator controller) to override the RC Controller to control the drone via a TCP link. Managed to did it successfully over a span of few days for our bench testing.
However, it just decided to stop working one day. The Joystick setup window still recognizes the input from the “joystick”, all channels assigned properly, but it just does not pass on the signal to Mission Planner. The Radio Calibration window does not react to the “joystick” at all.
All settings remain stock, also SYSID_MYGCS = 255 (default).
I think that’s when I unplug everything to disconnect.
When everything was running, I can still move the sticks and the sliders in the Joystick window still moves, but not the one in the Initial Setup - Radio Calibration.
2020-04-02 15:08:42,209 INFO MissionPlanner.MAVLinkInterface - Request stream EXTRA2 at 4 hz for 1:1 (:0) [Main Serial reader]
2020-04-02 15:08:42,456 INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (Len Fail) len 32 pkno 125 (:0) [Main Serial reader]
2020-04-02 15:08:42,456 INFO MissionPlanner.MAVLinkInterface - unknown packet type 199 (:0) [Main Serial reader]
2020-04-02 15:08:42,457 INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 209 exp 207 pkts lost 2 (:0) [Main Serial reader]
2020-04-02 15:08:42,561 INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (crc fail) len 30 crc 11820 vs 1513 pkno 35 RC_CHANNELS_RAW (:0) [Main Serial reader]
2020-04-02 15:08:42,565 INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 217 exp 215 pkts lost 2 (:0) [Main Serial reader]
2020-04-02 15:08:42,606 INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (Len Fail) len 23 pkno 158 (:0) [Main Serial reader]
I uploaded all the log.X files to this folder so you can easily access those. Also, I’ll check on the comm link too, normally I setup a separated router dedicated for this, but was using a common router just now
Well, I see bad mavlink packets all over, and looks like the joystick is working.
I also noticed that you use an old version of Mission Planner with something that is definitely not Ardupilot… Most of the parameters are looks like unknown to me…
Yeap for sure the joystick is working, as it’s detectable in the joystick screen, just that it stops overriding the RC control whenever I click “enable” now.
Also, previously it was on 1.3.70, I recently downgraded back to 1.3.65 to see if it was the new version of MP that caused the bugs (but well, didnt solve).
And you are right, this is a very custom build hahaha, anyways thank you so much for your inputs. I guess I’ll just wait for the software builders of the drone to look if they messed up something
hi, can you solve your problem? I had this too. but i run mission planner on linux and it recognize joystick in joystick setup page but in radio calibration stick does not work.
