I do need to go through the Pixhawk because of camera trigger for aerial surveying and post picture matching of GPS GeoTags. That would have been the easiest to do for sureā¦ā¦.
So after trying all I could think of, ended up using an extra camera trigger from GentLED I had. One is just for camera triggering via servo change from 1500 to 2000 and the other is a GentLED Still and Video unit. 1500 - 2000 triggers stills and 1500 to 1000 triggers video. Oh yeaā¦ā¦ this is for a NEX-5.
The GentLED Cam trigger is run by the Pixhawk on channel 7 and the other GentLED Still/Video unit is wired directly to the radio on channel 8.
Both GentLED units are shrink-tubed together and still fit nicely together on the front of the camera.
ADMIN - Please consider this NOT A SOLVED ISSUE. - - - - - The Pixhawk is not working on pass through option in the RC options full list.
Thanks,
Same thing happens with apm. i have a boscam hd19 that has a trigger. i have tested it though mission planner and can take photos but cant turn it back into record. i agree the trigger needs a 3rd location within the software
Hi, I am also setting up a Sony Nex7 with Gentles Shutter Plus IR triger, do you use a bec to power the IR trigger or connect your Gentles IR trigger directly to the AUX outputs on the PixHawk?
Under the copter.ardupilot.com/wiki/common ā¦ hout-chdk/ post they recommend a bec is used??
