Missing GPIO Button BTN_ENABLE on F405 FCs
Good day, folks.
I need to use GPIO Button for arming on SpeedyBee F405-Wing but there is no BTN_ category in Full Parameter List so I cant go by this manual.
Current AP ver. is 4.4.4.
Tried AC 4.4.4, AP 4.2 and still missing.
Also tried on Matek F405-MiniTE - still missing.
I cant find any information that F405 is not supporting Button Function. Also I tried to recompile custom build of the FW and there is also no options for enabling or disabling this function.
Screenshot 2024-01-16 141001
The only F405 I have flying has that function available.
Try updating to the latest Mission Planner beta version. I canโ€™t find a reason why this feature should be disabled, even on older hardware.
I use Button on my omnibusf405 boards so it should be there.
Yea, thatโ€™s the F405 board I have also.
Actually, I am on beta. Tried different MP versions and still missing. On the same time this list is shown on Pixhawk board or the Matek H743.
Guys, @rmackay9 @xfacta maybe you can suggest me something? Is that a FW compile bug? Or where should I dig at?
Thnx
Upd.
Thats not MP problem, I flashed F405-MiniTE with OmnibusF4 image and BTN_ENABLE parameter shows up. Of course, the FC is not working properly but now I find out that is FW related issue.
So what can I do with that, any thoughts?
Right here in the Hwdef.
Disable un-needed hardware drivers
define HAL_BUTTON_ENABLED 0
One of a long list of disabled stuff to save flash.
shouldnt this be added to the custom firmware options if its going to be disabled on some boards?
You would think so but as @cu-brick stated earlier itโ€™s not shown in any field.
I see these boards have <1024 flash so even wimpier than some other F405โ€™s I guess.
@tridge @rmackay9 any thought on this?
Oh, thank you a lot!
Thanks for the ping. Iโ€™ve added this to the Custom Builder Server issues list here.
How did I miss that?! Very obvious, but I guess I didnโ€™t just do the simplest search for โ€œbutton.โ€ Good to know.
