What’s the maximum cross wind for cubs pixhawk ? Maximum cross wind for the waypoint so the plane capable to follow the waypoint
I’m not an expert in that matter, but I’d say it is dependent on the airframe and not on the autopilot. The autopilot will try to reach the waypoint with the speed you set up. If there is crosswind the plane will fly skewed relative to the ground but still advance towards the waypoint. And that is where the airframe and the desired speed come into play: a slow flying glider with a top speed of let’s say 20m/s is a lot less tolerant against crosswinds than a 200 km/h fighter jet model (that probably has a stall speed above 20m/s ^^).
Thank you , I agree with you
