Hello Every one,
I’m using Pixhawk cube orange on hexa copter which is on the weel base of 1400mm frame; frame weight upto 6kg’s. What exactly I need is max speed that i can push it to limits ? and what the min to max that i can reach without any danger. will be in auto mode as a grid waypoints and also flying in the height of 100m
You do the experimentation and post your findings. Every craft is different.
