Max number of commands doubt
What is the maximum number of commands for a mission while using ArduCopter and Cube orange?
Approximately 700 waypoints.
I saw in the code a comment saying for pixhawk and copter would be 718, but I was not sure if it was also valid for cube orange
Remains the same for the Cube.
Lua scripting can be leveraged to load consecutive missions if you need more flexibility.
Cube orange only accepts lua scripts, right?Not other languages like python?
Correct. It’s baked into ArduPilot firmware for capable autopilots like the Cube Orange.
So i found the answer for the maximum number of WPs, rally points and geofence points(718, 46, 70 respectively), but while i was creating a mission, i got a message in the MP saying: Only 1306 items are supported. I had around 400WPs, so i believe that this also contains all of the commands in the mission, for changing the speed, camera contol etc.
Correct me if im wrong
I don’t know exactly the number, but be aware of creating missions with more than 400 wps can make your GCS run really slowly and eventualy crash GCS application.
