Well I am not having much success compiling such changes. As soon as I change the config.h to make my ESP32 a Mavlink switch I get compile errors. Maybe you can see the obvious issue – but I know you are busy.
See config.h attached. I only added the gs_txPin and gs_rxPin definitions to the relevant ESP32 variant 4.
I also made a change to main.ccp at line 1288 as this seems to be where you are handling the GCS mavlink serial. #if (defined TEENSY3X) || (defined ESP32)
This is my compile error.
src/main.cpp: In function ‘void setup()’:
src/main.cpp:364:5: error: ‘LogScreenPrintln’ was not declared in this scope
LogScreenPrintln("Starting … ");
Hi Marc, I tried your config.h this morning, and it clean compiled for me on Arduino IDE v1.18.19, and with ESP32 board version 2.0.10 (2.0.11 failed with a different minor issue):
After booting, the log says:
Starting MavToPass version:2.68.03
Display support activated: Landscape
64x128 text_size=1 char_w_px=6 char_h_px=8 scr_h_ch=8 scr_w_ch=21
EEPROM initialised successfully
EEPROM settings version:255.255.255
Version change detected. ALL SETTINGS IN EEPROM SET TO COMPILE_TIME DEFAULTS
EEPROM settings read and adopted
No FrSky port support selected or built in
Target Board is ESP32 / Variant is Heltec Wifi Kit 32
Mavlink WiFi In
Mavlink Serial Out
WiFi mode is STA>AP
Protocol is UDP IP-Targeted
No Bluetooth options selected, BT support not compiled in
E (3103) uart: uart_set_pin(692): tx_io_num error
ESP_ERROR_CHECK failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x4008d720
file: “C:\Users\erics\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\cores\esp32\esp32-hal-uart.c” line 215
func: uartBegin
expression: uart_set_pin(uart_nr, txPin, rxPin, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE)
abort() was called at PC 0x4008d723 on core 1
I need to deal with some other matters this morning, but I’ll look at it later when I get the chance. I’m assuming you are using a Heltec wifi kit 32 board.
Again I manage to miss your reply! I am actually using PlatformIO – can’t be doing with Arduino. And yes, using a Heltec WiFi board.
Anytime you get to it would be great but no rush. I think it would be great to have this as a configurable option. I am sure I can solve my compile issue. The errors you are seeing seem more germane.
Hi Eric. In addition to the tracker relay in my previous messages, I am making a new Ground Station to replace one stolen from my car. I have a working Dragonlink setup with a Heltech WiFi Kit 32 so this is just happening as fast as it happens. I purchased another Heltech board and found that the V2 that Noircogi got working for this project is not longer available. They are now selling the multi-core ESP S3 version. Of course its a mess with poor documentation and broken libraries. While I can flash it I have not made it work, yet. That likely means no-one else can either without some effort – it is more than just changing pin references. I was thinking about just getting a proper reference board and working with that. I know you are busy and I reckon I can get this up and running. I like the extra button it has well.
Hi Marc, unfortunately I don’t have any s3 boards yet. (I have some c3, c6 and s2s, but of course that’s not going to help). I’ll see if I can get an Adafruit board, but I’m back the SA for a while and shipping through the national post office is broken.
The only coding issue, I think, will be instantiating the correct serial objects (matching uarts with serial object names). I can do some of the basic work for you. The s3 has 3 uarts I believe, uart0 (for flashing and monitor), and uarts 1 and 2. Also, the Adafruit board uses SPI to drive the display, so those pins will not be available for other things.
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.614 Bat amps=0.210 mAh=0.410101 Total mAh=0.410 Bat1 cell count= 4
FrPeriod mS=6317 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.2 pt_bat1_mAh=0 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 190 ap_current_consumed mAh= 1 my di/dt mAh= 0
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.621 Bat amps=0.200 mAh=0.050876 Total mAh=0.461 Bat1 cell count= 4
FrPeriod mS=1014 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.2 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 170 ap_current_consumed mAh= 1 my di/dt mAh= 0
SPort detected
FrPort read good!
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.627 Bat amps=0.190 mAh=0.050575 Total mAh=0.512 Bat1 cell count= 4
FrPeriod mS=952 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 180 ap_current_consumed mAh= 1 my di/dt mAh= 1
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.630 Bat amps=0.180 mAh=0.051578 Total mAh=0.563 Bat1 cell count= 4
FrPeriod mS=1028 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 170 ap_current_consumed mAh= 1 my di/dt mAh= 1
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.633 Bat amps=0.180 mAh=0.053816 Total mAh=0.617 Bat1 cell count= 4
FrPeriod mS=1014 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.635 Bat amps=0.180 mAh=0.050575 Total mAh=0.668 Bat1 cell count= 4
FrPeriod mS=951 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.636 Bat amps=0.180 mAh=0.054666 Total mAh=0.722 Bat1 cell count= 4
FrPeriod mS=1029 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 190 ap_current_consumed mAh= 1 my di/dt mAh= 1
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.634 Bat amps=0.170 mAh=0.049973 Total mAh=0.772 Bat1 cell count= 4
FrPeriod mS=996 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.635 Bat amps=0.170 mAh=0.045758 Total mAh=0.818 Bat1 cell count= 4
FrPeriod mS=969 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.636 Bat amps=0.170 mAh=0.056805 Total mAh=0.875 Bat1 cell count= 4
FrPeriod mS=1013 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.637 Bat amps=0.170 mAh=0.050023 Total mAh=0.925 Bat1 cell count= 4
FrPeriod mS=997 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=1 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 170 ap_current_consumed mAh= 2 my di/dt mAh= 1
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.638 Bat amps=0.170 mAh=0.052116 Total mAh=0.977 Bat1 cell count= 4
FrPeriod mS=981 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.636 Bat amps=0.170 mAh=0.053975 Total mAh=1.031 Bat1 cell count= 4
FrPeriod mS=1016 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.635 Bat amps=0.170 mAh=0.050073 Total mAh=1.081 Bat1 cell count= 4
FrPeriod mS=998 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 180 ap_current_consumed mAh= 2 my di/dt mAh= 1
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.634 Bat amps=0.170 mAh=0.049270 Total mAh=1.130 Bat1 cell count= 4
FrPeriod mS=982 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.634 Bat amps=0.170 mAh=0.050776 Total mAh=1.181 Bat1 cell count= 4
FrPeriod mS=1012 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.633 Bat amps=0.170 mAh=0.053072 Total mAh=1.234 Bat1 cell count= 4
FrPeriod mS=999 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 190 ap_current_consumed mAh= 2 my di/dt mAh= 1
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.633 Bat amps=0.170 mAh=0.052116 Total mAh=1.286 Bat1 cell count= 4
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.633 Bat amps=0.170 mAh=0.050926 Total mAh=1.337 Bat1 cell count= 4
FrPeriod mS=1015 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.632 Bat amps=0.170 mAh=0.050023 Total mAh=1.387 Bat1 cell count= 4
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.633 Bat amps=0.170 mAh=0.052222 Total mAh=1.439 Bat1 cell count= 4
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.630 Bat amps=0.170 mAh=0.050826 Total mAh=1.490 Bat1 cell count= 4
FrPeriod mS=1013 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.630 Bat amps=0.170 mAh=0.052912 Total mAh=1.543 Bat1 cell count= 4
FrPeriod mS=997 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Mavlink from FC #147 Battery Status: bat id= 0 bat current mA= 180 ap_current_consumed mAh= 2 my di/dt mAh= 2
Mavlink from FC #1 Sys_status: Sensor health=51479583 Bat volts=16.630 Bat amps=0.170 mAh=0.051478 Total mAh=1.595 Bat1 cell count= 4
FrPeriod mS=968 Passthru out Bat1 0x5003: pt_bat1_volts=16.60 pt_bat1_amps=0.1 pt_bat1_mAh=2 pt_payload=0 passthru payload 0x10 00>00>00>00> ....
Hi Marc, I’ve added support for the LilyGo T-Display-S3, and also added some code to support your requirement. Github/mav2pt v2.68.06. PIO version included.
Eric - that is so kind of you to do that. I just made some time to finish this project. I am sure you saved me a lot of time mucking about myself. Will try it out shortly and report back.
Im just wondering, on my mav2pt setup (Dragonlink on relay), it works almost perfectly with yaapu telemetry on ethos. However, I noticed that I dont get any data for power and efficiency. all the rest works just fine. Is it something not included in mav2pt?
I can confirm it works if im not using my mav2pt+dragonlink. With my Frsky R9 and crossfire, Im able to fetch those data.
From your debug log above, this looks very suspicious:
Eric. Sorry it has taken so long to reply. Your support for S3 and for getting Mavlink in via WiFi and out via UART is working for my antenna tracker link from my Dragonlink. I notice online that almost no-one seems to have the Heltec Wifi Kit 32 V3 (S3) working with Adafruit libraries. However I did manage to get it working with #define SSD1306_Display // 170 x 320 dot 262K Color TFT LCD #define SDA 17 // I2C OLED board #define SCL 18 // I2C OLED board #define i2cAddr 0x3c // I2C OLED board #define SCR_ORIENT 1 // 1 Landscape or 0 Portrait
In addition I needed to assign reset to GPIO 21 in the SD1306_Display configurations. I think this should be done in the board configuration section above though, right? #ifndef OLED_RESET #define OLED_RESET 21 // Reset pin # (or -1 if sharing Arduino reset pin) #endif
So I guess you should add support for the Heltec WifiKit 32 V3 as it is the easiest one to buy on Ebay or Amazon (at least in the US). I can send you a tested config.h file for the latest stable release if you like.
I have not yet got this working but I will. I think it should be a reference board. You have a multi-colored LED to play with, a nice color OLED display, and three user defined buttons. I would be happy to send you a few of them if you cannot easily get them in SA.
I hope I can get time to add some more features as I am getting more comfortable this flavor of coding. I often need to choose different SSIDs in STA mode (iPad hotspot, Phone hotspot, and Home wifi). It would be great to be able to toggle between these.
Marc, all noted. Its a nice board, but presently out of stock on the web site. The problem here is that the “post office” is broken, but couriers are fine. I could buy some boards in Australia when I go after Christmas.in the meantime take a good look at the llygo t display s3. Nice big colour screen etc. But of course it’s not my call. Il see if I can add your ideas.
It has a neopixel style rgb led, but It’s also easy to add an neopixel RGB strip for status leds. Uses 1 pin, or possibly the same pin as the on board led.
I have a broken OLED on an old Heltec Wifikit 32 V2 on the Dragonlink so I wanted to replace it with an Heltec V3 (S3). I am using your WIP repo to flash another Heltec Wifikit 32 V3 and it seems when I try to compile with conventional options as a ground based Mavlink to SPort telemetry converter I get the following errors. So the WIP repo works as a Mavlink switch but no longer can generate a Frsky telemetry. I do not think this is related to the flavor of S3 ESP32 board.
In file included from src/main.cpp:137:
include/frSky_Ports.h:2986:14: error: no declaration matches ‘uint32_t FrSkyPort::getBaud(uint8_t, pol_t)’
uint32_t FrSkyPort::getBaud(uint8_t s_pin, pol_t pl) {
include/frSky_Ports.h:159:19: note: candidate is: ‘uint32_t FrSkyPort::getBaud(int8_t, pol_t)’
uint32_t getBaud(int8_t rxpin, pol_t pl);
include/frSky_Ports.h:41:13: note: ‘class FrSkyPort’ defined here
class FrSkyPort
Archiving .pio/build/heltec_wifi_kit_32_V3/libe54/libSPI.a
Indexing .pio/build/heltec_wifi_kit_32_V3/libe54/libSPI.a
Compiling .pio/build/heltec_wifi_kit_32_V3/liba3f/Adafruit_GFX_Library/glcdfont.c.o
Compiling .pio/build/heltec_wifi_kit_32_V3/lib9fc/Adafruit_ILI9341/Adafruit_ILI9341.cpp.o
*** [.pio/build/heltec_wifi_kit_32_V3/src/main.cpp.o] Error 1
Compiling .pio/build/heltec_wifi_kit_32_V3/lib169/BluetoothSerial/BTAddress.cpp.o
