I’m trying to learn to use MAVLink with my drone. I have arducopter installed on a speedybee f405 v4 stack, and I’m trying to communicate with a Teensy 4.1 board.
The wiring is as follows:
Teensy 4.1 → speedybee f405
vin → 5v
gnd → gnd
Rx1 → T1
Tx1 → Rx1
As for the programming, I’ve been following the code from this tutorial: MAVLink and Arduino: step by step
Here is what I have for now:
#include <Arduino.h>
#include <MAVLink.h>
#include <ardupilotmega/mavlink.h>
#define DEBUG 1
unsigned long previousMillisMAVLink = 0;
const long intervalMAVLink = 1000;
// # of heartbeats to wait before activating STREAMS from Pixhawk. 60 = one minute.
const int num_hbs = 60;
int num_hbs_pasados = num_hbs;
void Send_Data();
void Mav_Request_Data();
void Receive_Data();
void setup() {
Serial.begin(57600);
delay(2000);
Serial.println("Starting MAVLink");
void loop() {
Send_Data();
Receive_Data();
void Send_Data() {
mavlink_message_t msg;
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
// Pack the message
mavlink_msg_heartbeat_pack(1, 0, &msg, MAV_TYPE_GCS, MAV_AUTOPILOT_INVALID, MAV_MODE_PREFLIGHT, 0, MAV_STATE_ACTIVE);
// Copy the message to the send buffer
uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
unsigned long currentMillisMAVLink = millis();
if (currentMillisMAVLink - previousMillisMAVLink >= intervalMAVLink) {
// Modfiy the timing variables
previousMillisMAVLink = currentMillisMAVLink;
// Send the message
Serial1.write(buf, len);
// Request data from flight controller - requests data every num_hbs heartbeats, so every minute in this case
num_hbs_pasados++;
if (num_hbs_pasados >= num_hbs) {
Mav_Request_Data();
num_hbs_pasados = 0;
void Mav_Request_Data() {
const int maxStreams = 2;
const uint8_t MAVStreams[maxStreams] = {MAV_DATA_STREAM_EXTENDED_STATUS, MAV_DATA_STREAM_EXTRA1};
const uint16_t MAVRates[maxStreams] = {0x02,0x05};
for (int i=0; i < maxStreams; i++) {
mavlink_msg_request_data_stream_pack(2, 200, &msg, 1, 0, MAVStreams[i], MAVRates[i], 1);
void Receive_Data() {
mavlink_status_t status;
while (Serial1.available() > 0) {
uint8_t c = Serial1.read();
#if DEBUG
Serial.println("Serial is available");
#endif
// Try to get a new message
if (mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status)) {
// Handle message
switch(msg.msgid) {
case MAVLINK_MSG_ID_HEARTBEAT: {
#if DEBUG
Serial.println("\nReceived heartbeat");
#endif
break;
It’s very similar to the tutorial. I’ve modified the function names, and changed Serial to Serial1 for any communications between the teensy 4.1 and the speedybee flight controller.
Apart from that, it’s all very similar. There’s a few things that may be problematic. The first is what I should set for my heartbeat message and for my data request for the system Id and component Id. I couldn’t find any resources as to what you should set it to.
The big problem is that I’m receiving absolutely no response in my Receive_Data function. Nothing is happening.
I ran a basic condition, and Serial1.available() is always 0 when I run it.
Does anyone know what I’m doing wrong? Have I set my component or system ID values incorrectly, or is communicating with a speedybee and a teensy board just not possible?
Thank you for any help, I’m a bit lost here.
