Hello everyone,
I’m currently working with ArduPilot and an Orange Cube. I’ve been using version 4.3.7 and have encountered an issue while sending multiple MAV_CMD_CONDITION_YAW
commands. The drone starts to rotate as expected, but upon receiving the second command, it abruptly stops its rotation and resumes movement. My goal is to make the drone face a specific location while flying in a different direction, which requires sending multiple yaw commands at a high rate to maintain its heading.
After some research and experimentation, I came across a relevant post yaw commands at high rate. Following the suggestions in the post, I decided to downgrade to an earlier version (4.0.xx), which resolved the issue in most cases. However, I still encounter choppy movement when using the MAV_CMD_CONDITION_YAW
command relative to the drone’s position in high rates. For example, instructing the drone to rotate 10 degrees multiple times to complete a circle results in a choppy motion.
I’m wondering if there are any adjustments I can make within Mission Planner or the ArduPilot settings to address this problem. Additionally, I’m curious if there’s an option to remain on a higher version of ArduPilot and apply a fix for this issue. Any insights or recommendations would be greatly appreciated!
