Hello, I’m trying to use a Spektrum SPM9747 reciever with a Mateksys H743 Slim V3 FC, but for some reason I cannot see joystick movement on mission planner. I am sure that the reciever is binded to the radio.I only need RC input. From the documentation of the H743 on the bottom of this page, it seems like I only need to set SERIAL7_protocol to “23” for RC only? @amilcarlucas I saw that you posted an extensive blog on using the Mateksys H743 Slim and after looking at your 05_remote_controller.param file, I saw that the only parameter applicable to my situation is SERIAL7_PROTOCOL as the other params like Alternative Hardware configuration were for getting telemetry along with RC.
I currently have the Spektrum reciever signal pin wired to the Rx6 pin, which is what the Mateksys documentation lays out. There is a 4th pin in the reciever, but upon research, that pin seems like a NC pin to differentiate different generations of products in the spectrum lineup.
Any guidance is appreciated.
