I’m facing a problem to get telemetry from the Mateksys H743-SLIM board.
My receiver is Frsky R9 mini.
I’m using Ardupimot 4.17.
At the beginning I’ve tried to connect it as F.port with the following setups:
BRD_ALT_CONFIG = 1
FPort requires connection to Tx6 and SERIAL7_OPTIONS = 7 (R9 Mini set to F.port)
and then SERIAL7_OPTIONS = 135 (adding Tx Pullup).
Then:
BRD_ALT_CONFIG
to1
RSSI_TYPE
to3
SERIAL7_OPTIONS
to15
SERIAL7_PROTOCOL
to23
All of the above with another Frsky Rx: Archer R6.
Then tried to use SBUS and S.port (R9 Mini set to S.port):
SBUS connected to Rx6 & S.port connected to Tx6 (after to Tx7 as well):
At some configuration, Frsky SPORT = 4 I get reading of the sensors at the boot but then they are not functioning except from the Heading.
Don’t know what I’m doing wrong.
Please your help.
Thank you
Rotem
