Hi everyone,
I am quite new to ardupilot (not to RC though) and I am having a harsh time trying to get a GPS fix with my flight controller.
The hardware I am using is listed below :
FC : Omnibus F4 V3 Standard (I am converting the X220s from Eachine)
To sum up the situation :
When I connect the GPS module to U-center I can modify the different parameters in the configuration view (baud rate, update rate) and I can get a GPS fix in about 1 minute if I put the GPS antenna outside.
Then, when I connect the GPS module to the flight controller, I got “No GPS” error. I found that changing the Baudrate to 57600 solved this issue.
However, now even if the GPS module is recognized by the flight controller, I get no fix (even after 5-10 min). Worse than that, I can see that the sat_count is zero in the menu.
I tried to change different parameters in the configuration menu :
I tried : “disable auto config”
GPS type : “uBlox”
GPS Update rate : “10Hz”
I would greatly appreciate any help or advice on the matter because I must admit that I am quite lost at the moment.
Thank you in advance,
John
After getting this GPS fix in U-center, I proceeded to connect the GPS module to the FC about a minute after disconnecting it from U-center.
Doing so, I obtained a GPS fix in mission planner that lasted about 1-2 minutes. After that, I still get the error no GPS fix and the parameters bellow :
