Matek H743 Wing Components for Rover
Hey!
I would like to build a rover based on the Matek H743 WING or WLITE. My aim is to integrate a GPS and a time-of-flight sensor (probably VL53LOX-V2). I have planned an ESP32 as telemetry radio.
Now my question, do you know if the planned components are compatible? And: What would you recommend as a GPS? Preferably as inexpensive as possible.
Thank you very much!
If you only need general positional accuracy, and cheap is the top priority, then Google “m10 GPS with compass module”. I can only vouch for the Flywoo V3 at ~$20 but all the cheap ones are likely the same.
Thank you for the answer! And the cheap ones are all compatible with the H743? Or is there something else I need to consider?`
Nothing else to consider. You could try any of them, I have one of these I put on a quad to test out and never took it off. Cheap GPS module
I have a few of these too if you want to spend a bit more $$ Matek GPS module. They are very popular.
