I have purchased a F765 wing Fc
Should i use an external power module with Matek F765 . Will it work or do any damage to my FC
The F765-Wing has a voltage and current monitor built in. There is no reason to use an external power module. Just connect your battery to the battery solder tabs and the ESC and perhaps other devices that require battery voltage to the ESC solder tab.
