here does not specify which file I should use
http://ardupilot.org/copter/docs/common-matekf405.html
http://firmware.ardupilot.org/Plane/stable/MatekF405/
for this plate
I uploaded arduplane_with_bl.hex
and all the leds are getting access to this and the expected behavior?
individual firmware files for board types with ICM20602 and MPU6000 respectively have been added to „latest“, but not to „stable“ folder yet.
for your board version (STD type) you‘re good to go with the MatekF405 stable firmware.
but I do not use arduinopilot
to make the board feed i can use the 5v points and gnd anyone?
I was able to solve the LED problem now OK
