Any further changes are a significantly larger project. We have an EKF prediction of ground level that we would like to move to but this will be a slower project. We will also need to improve logging around this as you have noted.
There is a halfway solution where we could filter the ground level prediction that should let us set a lower filter value without getting oscillation. However this would be custom code that probably won’t end up in master.
@ohitstarik
I’m experiencing a similar (probably the same) issue and it seems to still be there in AC4.3.5RC1. Is there any other solution you can suggest to overcome it?
