While doing log analysis on a test log on 4.3.3 beta1, I tried to use magfit but the contents dialog runs off the bottom of the window so it’s not possible to press the “Run” button. Any idea if I can fix this in settings somewhere, or is it a bug?
I’m running MAVExplorer.py 1.8.59 from a clone I took direct from GitHub on the weekend. Also python 3.10.6
I’ve also been running into the same issue as @timtuxworth on Ubuntu (LTS, Pi-LTS, Budgie, PopOs). I’ve tried to re-size the screen but that didn’t help.
Thanks @rishabsingh3003 , I’m already running the dev version, so it was easy to try. It works immediately, I don’t even need to resize the dialog, the “Run” and “Close” buttons are now visible in the dialog.
Thanks for trying it out!
I am unsure if I can get it merged… it’s probably not the correct solution. It might need some rework. I did this as a short hack for you…
I do appreciate that @rishabsingh3003 , but if myself and @Allister are reporting the problem, for sure others are having the problem too, so I’m thinking it probably needs a proper solution.
