If you have a Pixhawk, or any other Flight Controller, with 1Mb flash, Lua scripting and some other functions are disabled. Not seeing the SCR_ENABLE parameter is your 1st clue. Which Pixhawk is it?
Ah I see thank you. I’ve got the Pixhawk 2.4.8, which I thought did not have the 1MB limitation?
Do you know of any way around this so I can control a WS2813 LED strip with my Pixhawk? I was hoping to set up some strip lighting on the arms for direction / status indication.
I would be happy to do that yes, although after upgrading and checking it is fmuv3 it seems none of my parameters have been reset. I can now see the SCR_ENABLE parameter, and I think that the Lua scripts I have uploaded are running!
I was about to try something similar when I found this thread. But it looks like I can forget about controlling WS2812 LEDs with a Kakute F7 AIO 1.5 since it apparently has only 1MB flash and thus supports no Lua scripting at all?
That would be a shame since I just got it to replace the originally planned Matek F722-SE which can’t run AP at all. Would the LEDs at least light up in white when connected to the LED pin?
Thanks, can you tell off hand what’s the cheapest (reliable) option that would run it? I would assume there is no F7 FC with more memory than the Kakute.
That’s beyond my budget for now but I’ll keep it in mind for next time, thanks. Actually it’s instantly visible (even to me) that those are high quality, and the ones on BG with the skewed connectors are not. I’d rather stick with a quality FC and leave the Lua experiments for later. Recently, I always ended up buying components twice when I had gone for the cheap option…
