hi sir its me again, sorry to bother you… what are the settings for mission planner? or this is just plug and play… thank you.
no it uses mavlink overwrite to control
becareful in test flight code is old so test it in safe aria
Hey what happens when objects are detected on any two opposite sides, i.e both front and back or left and right at the same time. Is there anyway the rc can be controlled so that the approaching obstacle closest (i.e. close to front or close to back) is detected and pitch and roll is sent to autopilot.
Like can it send command parallelly based on approaching object rate of approach.
I have edited this code to use the proximity instead of the RC override. I have only done some basic tests on it so far but it appears to work.
can you give me that code
[image]
