(NOS 3DR Iris+ package)
Iris+ Drone
FlySky FS-TH9X PCM1024 TX w/ FrSKY/DJT RF Module.
Telemetry fine originally.
Loaded Mission Planner Copter 4.1.1 Official firmware.
Lost telemetry to TX somewhere during calibrations.
I am not a computer guy.
Iris+ Drone
if its using frsky D telemetry, you need to set the serial port on the pixhawk in all parameters to mode 3 for Frsky D telemetry.
ā¦and this can be done in Mission Planner?
Update:
Telemetry screen on transmitter only shows RX % and āstabilizeā but the rest are all zeros.
Mission Planner shows all readings except for battery-level (zero).
System will arm properly and throttle responds (props removed).
When drone battery is disconnected TX shows blank telemetry screen w/ āNO DATAā at bottom so there was some signal.
ā¦and, I can no longer control the gimbal manually.
You could post your parameter file here. It might help diagnose the issues. In Mission Planner Config>Full Parameter List>Save to file. What version of Copter did you update from?
MP 1.3.75 build 1.3.7883.26610 ArduCopter V4.1.1 (01d1aa1e)
geofrancis suggested āneed to set the serial port on the pixhawk in all parameters to mode 3 for Frsky D telemetryā. I found where to do it in the configuration tab but needs āexternal converter hardware(?)ā to change the value.
Iām working on getting that parameter listā¦
Dave
I posted the file.
I guess the telemetry got screwed up with the introduction of the software.
Initially, out of the box, the motors would not arm but everything else appeared to be good. Thatās why I downloaded Mission Planner to diagnose the no-arming issue.
If I can get my telemetry back this drone would be ready to go.
Everything appears to be reset to default. No Flight Modes are assigned, Battery Monitor isnāt configured and Mount (gimbal) is not configured. All PIDās are at Copter default and I suspect there were specific ones for the Iris+.
But for now take @geofrancis advice and set SERIAL2_PROTOCOL to 3 from the Full Parameter List. Make sure to hit Save after making the change. See if that brings back more telemetry. You wonāt have battery voltage until you configure the battery monitor.
There is a parameter set in Github for this craft located here:
Iris+ parameters
Perhaps someone with direct Iris+ knowledge can comment but I think you have to configure many parameters to get back to where you were.
Thanx. Iāll check the Github list.
I appreciate all the help from everyone here.
Aināt new hobbies fun?
Do you have any flight log files from before you updated the firmware? We can extract the parameter file from the Flight Log and check the specific parameters required for the Iris+. These are on the Flight Controllers Sd card and can be downloaded from Mission Planner. Itās the .bin file we are after. You canāt attach it here directly, youāll have to place it in cloud storage somewhere (dropbox, etc.) and post a link to it.
No, I didnāt save anything before I updated .
The drone hasnāt been airborne, yet.
Thereās a FC SD card?
Although - HUZZAH!!! - I got everything back except manual control of the camera gimbal.
Progress!
Connect to Mission Planner and from the Data screen select āDownload dataflash log via mavlinkā. The dialog box that opens will list saved log files if present. Look at the date and choose one from before updating and hit Download Selected Logs.
For the camera gimbal update these parameters from the Github parameters:
MNT_ANGMAX_TIL,0
MNT_ANGMIN_TIL,-9000
MNT_MODE,3
MNT_RC_IN_TILT,6
MNT_TYPE,1
Start with MNT_TYPE and then refresh the parameters to show the others.
Well, it seems the MNT parameters have changed from the older version in the GitHub parameter file listā¦ But I think you just need to know which RC in channel(s) are being used for control and the new parameter names look to be self explanatory.
Iāll attempt the fix tomorrow. The drone &TX batteries went into low alarm and Iām not too far behind.
Again, I really appreciate all the help.
I am not able to open / read any log / bin files.
Iām going to have to backtrack on some of the parameters because, even though they run, the motors are not functioning properly - the front or rear stopping altogether with stick forward or back and sounding very unhappy when stick is left or right.
Frustrated, but not quitting - yetā¦
The logs open fine but you had an ancient version of Arducopter on there (3.2.1). The trick is to translate the parameters from that old version to 4.1.1. But, the parameter names have changed and there are many, many more available. Letās try this:
@rmackay9 Frank here has an Iris+ that he updated from 3.2.1 to 4.1.1 and many parameters were unsurprisingly reset to default. Is there a full parameter file around for 4.x that he can start with?
A parameter roadmap would be great!
Iāve got the Iris+ cooperating again - still no manual gimbal control though.
Will recharge, then retest everything tomorrow - at least whatever possible w/ props off.
I fly an ancient IRIS all the time (but with the latest firmware) so Iām sure we can get it flying well. Weāve got a 3.4 param file here for it but I guess I should replace that with a more up-to-date file for 4.1ā¦
