I think the only option for multiple modes is via the ground station app itself. There is no mixing on this transmitter so not sure how you can do more then three.
check this out
I try to buy that first but never arrives.
I have success conecting to an APM and Mission planner, It looks very easy to install and use, I did radio calibration well but then is like servos didn“t respond well so I choose default params in the APP and three options in chinesse appears (please SKYDROID if you can traslate for us?) I choose the first one to try and all looks to work well, I have to test if automatic modes respond well flying. I“m impressed to have an APM telem provided wire too apart from pixhawk one included.
you can also use other software instead of Skydroid version. QGroundcontrol and MissionPlanner for Android works very well and bluetooth connection as well.
I have tried both Mission Maker for Ardupilot and qGroundcontrol. Both work well with the 32 bit controllers. However I found the config functions gave me trouble with the older hardware. The flight function seemed to work just fine.
Hello. I just read this thread, and one thing worried me.
In the ānew improved versionā of the handset there does not seem to be a separate camera tilt and pan joystick, which was a MAJOR draw for me. And donāt forget a training port, or another way that the camera operation and flying can be separated out between two operators. Professional users like that.
Bonus points would be awarded by me, if the user can use his existing handset via a lead for the camera controller/second operator.
One idea that doesnāt seem to have occurred to any manufacturer (Iām thinking of one of the main reasons I still havenāt bought into DJI) is to add a tiny 5.8Ghz transmitter module to the handset system when there is integrated video so people can use EITHER a phone or their 5.8Ghz goggles⦠(or both when taking a āpassengerā for a ārideā) Iām well awre that this isnt; as simple as adding a little 5.8Ghz module there may also need to be some video reformatting for the different aspect ratios beteen hi-defās āletterboxā format and the (genrally) 4.3 format goggles like to use.
Also Iād like to throw my hat into the ring as a tester, for one reason that many people overlook.
Iām one of those people that stuff often does not work for! REALLY. Iāve had a long careeer as a repairer & systems analyst because of this traitā¦
We believe itās because I am ADD which tends to mean I almost never do things the same way twice, no matter how well it worked the first time. It works both for me, in that I tend to be able to āfind a wayā sometimes when others cannot to fix stuff, but poorly designed hardware gives me endless aggravation.
Iām unlikely to be able to talk as lyrically as some, and may not focus on the areas youād like, but let me use the hardware for a while, and if there is a way of messing it up, Iāll find it! I also fly very often, (Iāve been training myself hard this year, at one point i was flying a minum two batteries each flyable day.) As it happens I have a fleet of 450 sized airframes available ready to go. (I built a lot of 450 size copters before I realised that flying skills had to be built up just as much as the hardware!) so I donāt envision much delay between unpacking and flying. (I have one airframe that has proven exceptionally reliable, whenever I have taken it for a flug, so Iād bung it in that, for testing for the first month or so, then if it works, Iād try it in the hex that I am currently building which should incorporate all the good bits I have learned over the last ten years of RC.
I started out with RC 45 years ago with a homebuilt transmitter utilising a tiny tube (or āvalveā as we call them). Admittedly it didnāt work, (and I couldnāt afford the HT batteries, and lacked either an oscilloscope nor wavemeter, so as soon as I could I picked up a transistorised transmitter with the bang-bang steering) but really for me, RC totally changed about 10 years ago, and thatās when I reckon I really got āintoā it properly.
I hope my comments are acceptable and found to be reasonable, for a newbieās iorst post, and of course I donāt really expect my āoffer to testā to be taken up, although I do honestly think you ought to get at least one āklutzā on your testing teamā¦
first welcome to the subject of the Skydroid M12L, for someone with ADD I thought your post was interesting and articulate.
A couple things come to mind.
Your right about the training port, would be interesting to have one. Mind you DJI doesnāt have them on their Mavicā¦but it would be useful.
For the Pan and tilt Joystick. There is one on the unit.
I am not aware of a change to the device that removes it.
As for the 5.8 Ghz, this unit doesnāt support HD video or video at all. People are looking at devices such as this for video intergration
However the newer version has HD video integration according to the vendor. I am with you that it would be nice to have video out from the unit such that it can be ported to goggles or a monitor. Even the stand alone unit should have the ability to port the signal to goggles. IT does have however the ability to share via wifi. I have one ordered and will try it once I get it.
As for testing I would suggest you reach out to Skydroid direct. He may or may not be able to assist.
either way, glad your here.
We also have a facebook page if your interested
https://www.facebook.com/groups/492197374519805/
Thanks for the welcoming words. I donāt always hit the mark of āintersting and articulateā, so kind words indeed.
I looked at the pic of the forthcoming unit (I think, itās a few posts up from this one) and I couldnāt see the joystick control, maybe I didnāt look closely enough⦠Just wouldnāt want them to drop it having finally someone added it! And someone else commented about how it really is time most top end txās had at least one multi way switch! APM and itās derivatives are numerous enough and likely to stay for the forseeable future and a mode switch is darn good to have.
Like a growing number of people I donāt use facebook at all, so that particular option is closed to me.
Iām sure this thread will be followed regularly by Skydroid, & Iām equally sure he has plenty of volunteers already, so Iām content to leave my post here and give him a choice of reaching out to me or not, rather that asking directly, Iād imagine heās pretty snowed under already,so it seems a little more polite to do it this way.
Both the video devices youāve shown me convert 5.8 into wifi or otg/usb. Iām wanting something incorporated with these HD/long range video systems that supplies an alternative signal as well as the usually provided wifi hotspot on 5.8GHz, (and for completeness Iād like some CV out of the side on a 3.5mm jack for the wired goggle people)
Ah didnāt realize you where referring to the upcoming unit. you right I donāt see the joystick button.
That would be a mistake I think to leave it out. Itās very handy on the current device.
Skydroid, please take note.
cheers
Welcome Swallabat your suggestions are welcome more opinions better product to all
, I apreciate the two choices, with and without video because I use 5,8 and 1ā¦2 for longer range, little 5,8 fit nice under the phone too.
wellcome to family! Cheers! You mentioned trainer port etc features. Functionality of main unit M12L is the be link to groundstation, and m12l is as simple as possible but still offers possibilities for controlling. Simpliness offers many features like weatherproof etc. Groundstation (phone,pad, laptop etcā¦) offers more functionality like joysticks⦠fewer parts -> fewer possibilities for broken partsā¦
one question, is it possibility to use trims with M12L ? I have been flying with quad and trimming major controls cant be done with M12L⦠maby couldnt find only⦠I had to do trims with Missionplanner, so you need to take quad down for it. Live trimming would be great! maby it already has it but Im blind.
Hey Tom have you seen this Android app.
http://app.mi.com/details?id=com.shenyaocn.android.virtualjoystick
rrrr, ⦠suitable for co-pilot?
no idea.
Just found it snooping the site.
I have updated the manual with useful links now.
hmmm, how stable whole stack is, if there is laptop + phone + 2nd phone using virtual stick onlineā¦,⦠phones using btooth, and laptop usbā¦
hopefully i can get sorted with one of these contraptions soon or I will be playing catch up all the time its moving fairly fast at the moment
Ricky has your video mobile thingy arrived yet
Sad to say no Marty.
We had a postal strike here and its pushed delivery back a few weeks for most things.
But while I wait I will get the test rig out this weekend and get it airborneā¦thats something at least.
