Hi all,
Does anyone have dataflash logs from a well-tuned copter? I’m trying to adapt the code from betaflight’s PID analyzer to check rate control step responses and I’d like to see if my plotting is working correctly.
Any help would be appreciated.
Yuri_Rage
(Yuri Rage)
April 3, 2023, 11:44pm
2
This topic may be of use - several logs and param files linked.
I’m hoping to collect good working parameter files from all forms of multirotors.
The copter should be working quite reliably and well tuned.
Recent firmware version too, no old APM flight controllers!
I will enter the data into a spreadsheet and check for trends in parameters based on more than just prop size and battery cells (like the Initial Parameters screen in MissionPlanner does now). I wont necessarily be focusing on just PIDs, but anything that looks relevant.
The goal being to come…
andyp1per
(Andyp1per)
April 4, 2023, 3:53pm
3
I can send you one if you want
xfacta
(Shawn)
April 4, 2023, 10:23pm
4
Here’s a couple to start with, both are from the AC 4.0 era of firmware but PIDs are still valid.
450mm wheelbase quad with 9inch HQ props and 3S
700mm wheelbase quad with 12inch MR master airscrew props and 4S
Shared with Dropbox
Shared with Dropbox
That would be great, please do!
