Does the red light change when you put the sensor against your hand?
Have you got a 5v source connected to the servo 5v rail?
You need to connect a 5v regulator, the servo rail is not powered from USB.
how can i use lua script can you explain to me
Is the sensor working? Is it showing as a button press on mission planner messages?
ok 1 moment i will do
The red light should change when you put the sensor up to your hand if its working correctly.
no no sensor now not working
Is the red led on the sensor changing? Have you connected 5v ?
is px4 dosnt give 5v ?
No you need to connect an additional 5v to the servo pins.
hmmm which one pin 5v servo
Any of the servo outputs will work
Connect the 5v power to any of the pins with the red and black line and it will power your sensor on aux1.
i did its working but i cant see that reaction on missionplaner
here we can limited for that if can you connect to this for more comfotable contact https://www.instagram.com/didar_purliyew
i cant get reaction from px4 cube on mission planner
are you getting a reaction here on mission planner
https://discuss.ardupilot.org/uploads/default/original/3X/f/9/f9538ec38230e3622569df9d1078401120f0517a.jpeg
try and set BTN_OPTIONS1 =1 that will invert the input so a high signal from the sensor board will activate it rather than a low signal.
no no i cant got reaction button data
