I’ve investigated the LidarLite PWM driver not working under ChibiOS. I’m afraid to say that this is a known missing feature of ChibiOS. It’s on the to-do list to add support for RangeFinders that output PWM but it’s unlikely to be done for the 3.6.0 release. It’s possible we will resolve this in a later point release (i.e. 3.6.1, 3.6.2, etc). Until then I’m afraid the NuttX build is the one to stick with if the LidarLite PWM range finder is a required.
Edit:
I have not checked yet if the PWM driver is now working because I have changed to I2C connection which is working now for me.
I have just built a I2C cable for lidar light v3, I have capacitor in circuit and have checked Voltage 5.3v from mauch PC. Settings per wiki, To check function I went into status and do not have senor show up at all, I can see power to Lidar pulsing red led/ lazer through small gap at cable connection so it appears to be working. I previously connected via PWM again with properly set up cable, but again no sensor or lidar readings in status page. Do other conditions need to be met EG 3d fix etc for a reading to occur… I2C errors =0, Date on lidar is 2020
