Hello everyone , I’ve been experiencing a specific problem for a while now and I don’t know if this might be due to a set of parameters I have to set or limitations of ardupilot . You can also try my setup to see your results.
My test was done by activating only these two values in the LOG_BITMASK: IMU , PID
Flying for about 15 minutes , the log reached a size of about 20 mb . By connecting with the usb to the drone WITHOUT turning it off , I can see the log and download it .
After I turn off the drone and turn it back on and reconnect with Mission Planner , the log size became (0) .
When instead I generate a low log size 1-9 mb this event does not happen .
What happens very simply , is that logs between 10 and 20mb in size , and I assume even larger than 20mb , are deleted from the sd card after turning the drone off and on again .
The sd card works perfectly , since the logs are saved normally and remain saved after turning off and on the drone , but only if under a certain size
That is unfortunate, if it is a custom drone with a custom firmware, there are no way to find out remotely what happening.
AP deletes the last log if there are less than LOG_FILE_MB_FREE megabytes free space is on the storage.
Either this parameter is wrong or your solid state storage wrongly report free space…
Thank you very much for the help I appreciate it , you are absolutely right with a custom drone , it is complicated to understand the problem .
For the record the LOG_FILE_MB_FREE parameter is set to 500
If it seemingly works, then note that this will not solve the problem, just mask it.
In this case the root cause is that the storage wrongly reports free space.
The drone is collecting the log ,as soon as it is finished I will report the result to you .
I understand what you mean ,
the AP believes that the sd card has less available space than the LOG_FILE_MB_FREE parameter and therefore deletes the last log
Mm , now with a log of 11mb , it seems to have remained in the sd card even after shutting down . Now I will try to get a log of at least 20mb to confirm .
Yep , seems to have solved the problem . With a 20mb log , it remained even after turning the drone off and on again .
So somehow the sd incorrectly reports its total size to the AP
