I m building a quad with kakute f7 and I want to connect to out M6 a servo
I read at the ARDUCOPTER that
If using Copter, connect the servo to AUX OUT 1, 2, 3 or 4. MAIN OUT 1 ~ 8 should be avoided because these update at 400hz.
What changes should I do to parametrs list to make a servο work as a gripper at M6 out?
@cookmangr „main“ and „aux“ pin syntax refers to pixhawk-type boards that have a dedicated IO- coprocessor running the „main“ pins, while the „aux“ pins are directly FMU-driven.
kakute does not have that coprocessor, so all pins are driven by FMU directly.
when mixing non-standard motor-type signals (dshot etc.) and standard servo-type PWM on your outputs, you‘ll have to pay attention to the fact that the output pins are usually packed in groups of 2 or 3 running on a common timer. pins within one timer group need to run the same signal type. see section „PWM out“ on: http://ardupilot.org/copter/docs/common-holybro-kakutef7aio.html for detail.
