JSON sensor issue - SITL/GAZEBO
I’m trying to have Arduplane/SITL/Gazebo “Garden” on a WSL Ubuntu 22.04
I followed the doc https://ardupilot.org/dev/docs/sitl-with-gazebo.html
  • To have Gazebo running, I had to change the command (it’s due to a graphic card issue, I found that in the Gazebo forum)
gz sim -v4 -r zephyr_runway.sdf
I use this one instead:
gz sim zephyr_runway.sdf ign gazebo --render-engine ogre
And Gazebo seems to work
For SITL, in the doc:
sim_vehicle.py -v ArduPlane -f gazebo-zephyr --model JSON --map --console
SITL/Mavproxy is starting , but it seems that the JSON sensor are not working, so nothing happen and I’ve got these errors messages:
Usually I’m not using JSON for SITL, first time because of Gazebo, I didn’t find a way to make it work, so thanks for your help
Nico
Hello @Nicolas_T, it appears that the SITL instance is not connecting to the simulation running in Gazebo. It could be that the ardupilot_gazebo plugin is not being found.
Could you run the Gazebo server and GUI separately with the following commands and post the logs:
server:
gz sim -v4 -s -r --render-engine ogre zephyr_runway.sdf
gui:
gz sim -v4 -g --render-engine ogre
If you see a message saying the ArduPilotPlugin is not found you’ll need to export
GZ_SIM_SYSTEM_PLUGIN_PATH with the path to the plugin.
Also note the -r flag on the server - this starts the simulation running. There will be no connection while the simulation is paused (which is the default start state).
Hi Rhys,
It works fine, that’s so great, many thanks for your help !!
Nico
