Hello everyone.
This is my first drone build. I used a rpi 4b and a navio 2. I initialy planned to use the flysky fs-I6 with the
fs-ia6 reciever and a ppm encoder but came acros a problem that i cant fix right now so I changed my plans. I am now trying to use the Logitech extreme 3D pro joystick as controller. Now my problem: I set up my joystick in the joystick tab in the setup section under optional hardware. Everything seems to work fine until I connect to my drone. My zero values (who normally are 1500) are now 1015. I am expierencing the same problem as this guy: Joystick pwm config positions change after Arduplane connection .
Thank you al for your help.
kind regards,
Oscar
