Anyone had similar experience. I tries to do some long range video flying in acro mode but found alot of small vibration at inteval of per half seconds.
But when i change to althold and poshold it seems all gone.
I suspect it has to do with slow bitrate from my elrs controller? It is causing unneeded movement.
Because I set my bitrate to the lowest to enable longest range. What do you think? Do you have similar problems before?
