It's posible to reverse Rover in autopilot?
Hi. I’m working in a proyect with Rover.
I need it to go backwards in autopilot. It’s posible?
I use Mission Planner. I think that is not posible with him because i see a parameter wp_speed_min that his value can’t be less than 0.
Maybe there is a parameter to reverse in some situation, but i don’t see it.
Do u know any solution? Other sofware… maybe is necesary to program it.
Thanks.
as part of a mission, or guided?
I need it as part of a mission.
yes its possible, look at do_set_reverse
Thank your.
I had try it, but it didn’t work. I see that the problem was that my ESC is not correct to use it.
