I’m trying to get arduplane working on my version of the obal board. I’m using Raspberry pi zero 2 w (same cpu die as Rpi3B).
The board expects individual servo channels on its inputs. Unfortunately in mission planner there is no activity at all on Radio calibration page.
So I built the examples/RCInput tool to check if this is an issue with my hardware. When running the tool it displays all 8 inputs with correct values changing as expected.
Are there any configuration items I should review? For example I read somewhere Sbus input requires a serial port. What about the legacy RC inputs, do I also need to configure one of serials for it?
I have all serial ports set to disabled other than no 0 (mavlink) and 1 (GPS).
Perhaps there are some debug settings I can use to get to the bottom of it?
