Hi All,
I am using a Holybro Kakute H7v2 as the flight controller for my drone. I flashed it with the latest stable Ardupilot release firmware. After connecting the drone to the mission planner, I get an error message stating “Config Error: Baro unable to initialize driver”.
I tried to fix this issue by adding an external barometer (MS5611) via the I2C pins (SCL, SDA, 5V, GND all soldered) but am still facing the same issue. I updated the relevant calibration parameters(BARO_PROBE_EXT and BARO_PRIMARY).
Also, I tried to flash with other firmware releases but nothing works.
Is there any way to solve this issue?
Thanks in advance!
