Hello All,
I’m having an issue downloading logs over telemetry from ardupilot using mavlink messages (using Mavlink V1 protocol - Node.js and ArduCopter v3.6.11)
I’m able to use the LOG_REQUEST_LIST message to fetch the list of log files on the drone and I’m successfully receiving the LOG_ENTRY response message back.
Next, I create the LOG_REQUEST_DATA request message and then write it to the serial port.
var request = new mavlink.messages.log_request_data(targetSystem, targetComponent, 1, 0, 90);
Request object:
format: ‘<IIHBB’,
order_map: [ 3, 4, 2, 0, 1 ],
crc_extra: 116,
fieldnames: [ ‘target_system’, ‘target_component’, ‘id’, ‘ofs’, ‘count’ ],
target_system: 1,
target_component: 1,
ofs: 0,
count: 90
After that point I do not receive any message back with the name LOG_DATA.
What could I be doing wrong? Please let me know if any other information is required. While debugging, I found that the same function works when I download logs using Mission Planner or QGroundControl. For some reason, when my script sends the command it does not seem to work.
Thank you for your time,
Amar
