Hello, I have a drone with two proximity sensors mounted front and back. Everything is working fine in Loiter and Althold when an obstacle is detected. I have carefully set the parameters, and the drone applies brakes whenever an obstacle is detected. In AUTO mode, bendy ruler is applied and the drone finds the path towards the waypoint and avoids obstacle by going around the obstacle.
But my requirement is that when and obstacle is detected in AUTO mode, or in RTL mode, instead of following bendy ruler or anything else, the drone should just apply hard brakes or switch to Brake mode.
@rmackay9 is there any way to do this in the latest version? If yes can you give a brief explanation. @rishabsingh3003 you also implemented something like this if I am not wrong. Can you please give me an insight regarding this?
Proximity sensors are exposed to Lua scripts now so it could be done. I’m coincidentally working on adding support for “simple avoidance” (aka stopping) in Auto mode this week although it’s a little tricky and so it is possible that I won’t be successful and it would initially go into 4.6 (not 4.5).
I’ve flown it on real vehicles and it works but I’m planning some further enhancements to make the vehicle stop faster. This won’t make it into 4.6 I’m afraid but surely it will be in 4.7.
Thanks for the reply. I am currently running 4.4.X on my drone. Will this work on this version? If yes, can I get the lua script or can I know how to configure the same on my drone?
Sorry, it won’t be possible to backport it to 4.4. 4.6 would be the earlier version that it could be ported too but realistically I think for most people it will be 4.7.
