I have an old drone I am upgrading. It uses 10 inch props. As I search the Internet and drone shops I do not see any drone frames that will allow 10 inch props. Do I have something ancient compared to today’s stuff? In fact, I never see anything more than 7 inch it seems.
I’ve walked the same path this year. Ended up replacing everything except for the Turnigy 9X.
Yes, common attention has shifted towards smaller and faster copters and there is a whole new generation of pilots out there for whom FPV strictly equals copter racing. It’s the new norm.
Regarding your hardware: gotta see the exact list. I guess most of it is still flyable, but not as efficiently. Over the years motors have gotten more efficient (g/W), ESCs lighter (4x20A Q-Brain is 50 g without the heatsink and overheats, 4x45A Mamba is <20 g and doesn’t), VTXs lighter and significantly more powerful (not to mention digital video!), FPV antennas much better tuned, etc.
I had a 1.25 kg empty weight 10" flying brick that barely held in the air for 10 minutes, now I have an 11-12" 750 g empty weight that flies for 50 minutes, probably an hour.
10" is a dead-end in my opinion. Too big to fly acro and crash frequently, too small to be efficient. If you’re ready to upgrade and looking for the same flying experience as 10 years ago, I’d probably recommend looking into 12-14". Still cheap (relative to the big dudes), but more efficient.
Assuming you want to fly FPV, the bigger and heavier the frame, the more damage to it (and, potentially, surrounds) will be when it crashes
If you want to film movies with a big camera, then big, heavy and stable will be better Then you’ll want a hex or octo for redundancy (if one motor fails, hex will still land, and even remain controllable).
I have 4 900Kv 2830s motors I cannot even see where they are listed in motor data bases.
4 in 1 ESC JHEMCU BS 40A BLHeli_S I think this is an older ESC without BDshot and telemetry
Matek H743 slim FC
FlySky FS-iX6 10 channel radio
You say that 12-14 inch are available. Those are much larger than my 10 inch or hyuonder year.
I think I will go ahead and configure my drone with these parts and perhaps later upgrade again to a smaller frame.
I still would like to know how people size the frame - motor size - ESC - FC - battery
I must say that I am more interested in learning about the technology in the drones than in the actual flying of them. Mission planner is challenging but very interesting to learn about along with learning about motors, ESCs, weight, betteries, and etc. Putting all of this is fun but a bit difficult. Yesterday, I was trying to push a connector into my H743 FC and the connect broke off on the FC. Fortunately, there are solder pads I can connect to. That was a $97 FC.
A 1 month subscription is the same as one set of props for a 5" FPV quad. A year is less than two sets. If you’re flying anything larger, and the program saves you one “testing” one set of props then you’re cash ahead. Let’s not even talk about motors, batteries and ESCs.
But if you like the math, and you can find the data yourself then go for it. Just offering a potential solution.
you are probably correct but still I want to learn about the technology rather than have a program just give me the answer. I guess the hard part is getting the data for the props and motors.
Ecalc is a tool, like a calculator. It doesn’t say buy this or that. You still need to adjust the variables and evaluate the possibilities. Just like a calculator saves you from doing arithmetic, you still need to work out the maths.
