Thank you for the reply @rhys . Also Micro_ros should be installed in the flight controller right?
No, we are not using micro-ROS, but DDS eProsima micro XRCE DDS directly (they are different). We use the micro-ROS agent on the PC / companion computer to connect the DDS comms from the flight controller to the ROS 2 network.
I have tried to connect Cube Orange Plus with ros2
in terminal I can see that dds connection is working but Iâm not able to see any topics in ROS2
Am I missing something? I have tried it with running mavproxy but still no luck!
Workstation-PC:~/ros2_ws/src/ardupilot/libraries/AP_DDS$ ros2 run micro_ros_agent micro_ros_agent serial -b 115200 -r dds_xrce_profile.xml -D /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02
[1716818954.908877] info | TermiosAgentLinux.cpp | init | running⌠| fd: 3
[1716818954.909521] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 4
[1716818986.718754] info | TermiosAgentLinux.cpp | fini | server stopped | fd: 3
[1716818986.728907] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818987.733142] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818988.736850] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818989.740287] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818990.743772] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818991.744622] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818992.748691] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818993.750880] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1716818994.712218] info | TermiosAgentLinux.cpp | init | running⌠| fd: 3
[1716819003.037712] info | Root.cpp | create_client | create | client_key: 0xAAAABBBB, session_id: 0x81
[1716819003.037816] info | SessionManager.hpp | establish_session | session established | client_key: 0xAAAABBBB, address: 0
[1716819003.047283] info | ProxyClient.cpp | create_participant | participant created | client_key: 0xAAAABBBB, participant_id: 0x001(1)
[1716819003.049949] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x000(2), participant_id: 0x001(1)
[1716819003.050076] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x000(3), participant_id: 0x001(1)
[1716819003.050526] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x000(5), publisher_id: 0x000(3)
[1716819003.053347] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x001(2), participant_id: 0x001(1)
[1716819003.053428] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x001(3), participant_id: 0x001(1)
[1716819003.053680] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x001(5), publisher_id: 0x001(3)
[1716819003.056364] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x002(2), participant_id: 0x001(1)
[1716819003.056409] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x002(3), participant_id: 0x001(1)
[1716819003.056621] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x002(5), publisher_id: 0x002(3)
[1716819003.059660] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x003(2), participant_id: 0x001(1)
[1716819003.059699] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x003(3), participant_id: 0x001(1)
[1716819003.059875] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x003(5), publisher_id: 0x003(3)
[1716819003.062248] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x004(2), participant_id: 0x001(1)
[1716819003.062294] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x004(3), participant_id: 0x001(1)
[1716819003.062464] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x004(5), publisher_id: 0x004(3)
[1716819003.065453] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x005(2), participant_id: 0x001(1)
[1716819003.065505] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x005(3), participant_id: 0x001(1)
[1716819003.065800] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x005(5), publisher_id: 0x005(3)
[1716819003.068477] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x006(2), participant_id: 0x001(1)
[1716819003.068556] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x006(3), participant_id: 0x001(1)
[1716819003.068892] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x006(5), publisher_id: 0x006(3)
[1716819003.071338] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x007(2), participant_id: 0x001(1)
[1716819003.071367] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x007(3), participant_id: 0x001(1)
[1716819003.071514] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x007(5), publisher_id: 0x007(3)
[1716819003.074261] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x008(2), participant_id: 0x001(1)
[1716819003.074297] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x008(3), participant_id: 0x001(1)
[1716819003.074447] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x008(5), publisher_id: 0x008(3)
[1716819003.077400] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x009(2), participant_id: 0x001(1)
[1716819003.077428] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0xAAAABBBB, publisher_id: 0x009(3), participant_id: 0x001(1)
[1716819003.077519] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0xAAAABBBB, datawriter_id: 0x009(5), publisher_id: 0x009(3)
[1716819003.080399] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x00A(2), participant_id: 0x001(1)
[1716819003.080461] info | ProxyClient.cpp | create_subscriber | subscriber created | client_key: 0xAAAABBBB, subscriber_id: 0x00A(4), participant_id: 0x001(1)
[1716819003.080612] info | ProxyClient.cpp | create_datareader | datareader created | client_key: 0xAAAABBBB, datareader_id: 0x00A(6), subscriber_id: 0x00A(4)
[1716819003.083733] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x00B(2), participant_id: 0x001(1)
[1716819003.083788] info | ProxyClient.cpp | create_subscriber | subscriber created | client_key: 0xAAAABBBB, subscriber_id: 0x00B(4), participant_id: 0x001(1)
[1716819003.084000] info | ProxyClient.cpp | create_datareader | datareader created | client_key: 0xAAAABBBB, datareader_id: 0x00B(6), subscriber_id: 0x00B(4)
[1716819003.086676] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x00C(2), participant_id: 0x001(1)
[1716819003.086763] info | ProxyClient.cpp | create_subscriber | subscriber created | client_key: 0xAAAABBBB, subscriber_id: 0x00C(4), participant_id: 0x001(1)
[1716819003.087018] info | ProxyClient.cpp | create_datareader | datareader created | client_key: 0xAAAABBBB, datareader_id: 0x00C(6), subscriber_id: 0x00C(4)
[1716819003.089536] info | ProxyClient.cpp | create_topic | topic created | client_key: 0xAAAABBBB, topic_id: 0x00D(2), participant_id: 0x001(1)
[1716819003.089587] info | ProxyClient.cpp | create_subscriber | subscriber created | client_key: 0xAAAABBBB, subscriber_id: 0x00D(4), participant_id: 0x001(1)
[1716819003.089862] info | ProxyClient.cpp | create_datareader | datareader created | client_key: 0xAAAABBBB, datareader_id: 0x00D(6), subscriber_id: 0x00D(4)
[1716819003.093843] info | ProxyClient.cpp | create_replier | replier created | client_key: 0xAAAABBBB, requester_id: 0x000(7), participant_id: 0x001(1)
[1716819003.097386] info | ProxyClient.cpp | create_replier | replier created | client_key: 0xAAAABBBB, requester_id: 0x001(7), participant_id: 0x001(1)
If anybody got this working please help
If all the topics match, but no nodes or topics appear in the ROS 2 CLI, check you have ROS_DOMAIN_ID
set to ââ.
Hi @rfriedman
current ROS_DOMAIN_ID set to 22
Here is data from my bashrc file:
NB: Using orange cube_plus+ connected to the laptop using a USB cable
source /opt/ros/humble/setup.bash
export ROS_DOMAIN_ID=22
export ROS_LOCALHOST_ONLY=1
export PATH=$PATH:~/Micro-XRCE-DDS-Gen/scripts
export GZ_VERSION=garden
source /home/ubuntu/ardupilot/Tools/completion/completion.bash
export PATH=$PATH:~/.local/bin
export PATH=$PATH:/usr/local/lib/python3.10/dist-packages/MAVProxy
Try export ROS_DOMAIN_ID=0
. Currently this choice is hardcoded in the AP_DDS
library. Can you also post the output from the micro_ros_agent
when run with the verbose flag (-v6
Hi, I got this working after setting ROS_DOMAIN_ID=0
and disconnecting from the internet while running.
:~/ros2_ws$ ros2 topic list
/ap/battery/battery0
/ap/clock
/ap/cmd_gps_pose
/ap/cmd_vel
/ap/geopose/filtered
/ap/gps_global_origin/filtered
/ap/imu/experimental/data
/ap/joy
/ap/navsat/navsat0
/ap/pose/filtered
/ap/tf
/ap/tf_static
/ap/time
/ap/twist/filtered
/parameter_events
/rosout
Hi Im trying the same in jetson orin nano with JP6.
But when i try to run Iâm encountering this error anyone know why this is happening ?
it says dds_xrce_profile.xmlâ file is missing !!!
But the same work perfectly in my Ubuntu 22.04
/ros2_ws/src/ardupilot/libraries/AP_DDS$ ros2 run micro_ros_agent micro_ros_agent serial --baudrate 115200 --dev /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02 --refs dds_xrce_profile.xml -v6
Error: reference file âdds_xrce_profile.xmlâ does not exist!
Usage: âmicro_ros_agent <udp4|udp6|tcp4|tpc6|canfd|serial|multiserial|pseudoterminal> <>â
For a more detailed description about all the available arguments, please execute the agent with â-h/âhelpâ option.
My bashrc file for reference
export PATH=$PATH:/home/ceed/ros2_ws/Micro-XRCE-DDS-Gen/scripts
export ROS_LOCALHOST_ONLY=0
source /home/ceed/ros2_ws/src/ardupilot/Tools/completion/completion.bash
export PATH=â$PATH:$HOME/.local/binâ
when i manually added this dds_xrce_profile.xml
this error resolves but still communication between jetson and cube doesnât happening!
Output:
:~/ros2_ws/src/ardupilot/libraries/AP_DDS$ ros2 run micro_ros_agent micro_ros_agent serial -b 115200 -r dds_xrce_profile.xml -D /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if00
[1719469514.466439] info | TermiosAgentLinux.cpp | init | running⌠| fd: 3
[1719469514.470243] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 4
The need for a refs file was removed from master
in AP_DDS: replace ref interface with binary interface in uxr create entity methods by srmainwaring ¡ Pull Request #27145 ¡ ArduPilot/ardupilot ¡ GitHub. It is still needed for the 4.5 release, but when running master
drop the --refs dds_xrce_profile.xml
option as the file has been removed.
hi @rhys thankyou âŚ
without --refs tag it gives this error
[1719989749.355267] info | TermiosAgentLinux.cpp | init | Serial port not found. | device: /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02, error 2, waiting for connectionâŚ
[1719989749.914499] info | TermiosAgentLinux.cpp | init | running⌠| fd: 3
[1719989760.155230] info | Root.cpp | create_client | create | client_key: 0xAAAABBBB, session_id: 0x81
[1719989760.155644] info | SessionManager.hpp | establish_session | session established | client_key: 0xAAAABBBB, address: 0
2024-07-03 10:56:00.562 [XMLPARSER Error] Profile âparticipant_profileâ not found â Function fillParticipantAttributes
And even with --refs dds_xrce_profile.xml` the ardupilot-cube need to disconnect and connect it back again to establish connection , is there any known workaround for that as-well?
FYI
When i rebuild all ros2_ws from scratch to get new updates
then the output is : -
~/Desktop/ros2_ws/src/ardupilot/libraries/AP_DDS$ ros2 run micro_ros_agent micro_ros_agent serial -b 115200 -D /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if02
[1719994442.842010] info | TermiosAgentLinux.cpp | init | running⌠| fd: 3
[1719994442.842769] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 4
I have tried running mavproxy.py in other terminal but still not creating topics
But when I try checking stream using command , I can see the data flowing âŚ
~/Desktop/ros2_ws/src/ardupilot/libraries/AP_DDS$ python3 -m serial.tools.miniterm /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if00 115200 --echo --encoding hexlifyâ Miniterm on /dev/serial/by-id/usb-CubePilot_CubeOrange+_1A0032000D51323031393637-if00 115200,8,N,1 â
â Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H â
01 A7 68 88 FD 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 61 4B FD 14 00 00 EE 01 01 F1 00 00 44 BA 1A 10 00 00 00 00 C6 F2 42 3C 0F 89 D7 3C 5F 7A A9 3C EC 84 FD 29 00 00 EF 01 01 93 00 00 FF FF FF FF FF FF FF FF FF 7F EA 00 FF FF FF FF FF FF FF FF FF C9 FD 1C 00 00 F1 01 01 A3 00 00 FE 8C C6 B8 6D 7F 6F 35 C4 66 B3 B9 00 00 00 00 00 00 00 00 F6 5E 1A 3A 10 3F 89 3C 61 15 FD 0C 00 00 F2 01 01 B2 00 00 F3 AB 46 40 C6 EB 50 BC A1 D8 8C BE 07 D3 FD 1C 00 00 F3 01 01 1E 00 00 6E 20 04 00 DB 72 46 40 2A D9 C4 BA E3 E2 8B BE 77 B3 AC B8 A4 38 7C B8 7A CB D7 B9 AE FE FD 1C 00 00 F4 01 01 21 00 00 6E 20 04 00 00 00 00 00 00 00 00 00 22 06 00 00 28 06 00 00 00 00 00 00 00 00 83 86 FE 19 FD 12 00 00 F5 01 01 4A 00 00 00 00 00 00 00 00 00 00 C2 F5 C8 3F 01 AE 92 3F 58 01 96 F3 FD 1F 00 00 F6 01 01 01 00 00 0F DC 30 13 0F 00 20 12 0F 81 10 03 46 00 E6 00 âŚ
@mefrankli, Iâve added a note describing how to run a HW test on a laptop using a CP2102 USB-to-UART bridge to provide a second USB connection: Testing PPP and DDS on a desktop or laptop
