Is it possible for a companion computer using dronekit commands to change the drone’s pitch/yaw/roll angles while making the drone hover in place or in the same vicinity? E.g. drone pitches 60 degrees and hovers in place.
If so, how can it be achieved? What parameters to set, commands to send or modes to use?
Thanks for the response. I do not have a specific use case right now. I was just wandering if it is possible for futute use. Also, I just found about the LOIT_ANG_MAX parameter that has a 45 max angle.
