Is Dshot on a pixhawk mini possible?
Considering that you are supposed to use the aux outs above 1-8, and the pixhawk mini only has 8 outs, is it possible to run Dshot on a pixhawk mini?
Thanks!
Somewhere Randy has written that for 3.6. it will not be available for IO processor. That means you need a board with Aux out.
Or no co-processor. PixRacer for example.
Yes pixracer should work.
Or one of the F4/F7 boards now supported in Arducopter Chibios. Lot’s of options now!
The answer is pretty much provided above, but to be clear: Pixhawk mini only provides the io coprocessor outputs. It doesn’t break out the fcu outputs. So doesn’t support DShot.
