IRC tramp setting not working
Hello, I have been using rushtank with smartaudio for a while. it works perfect.
recently, I tried with another VTX with IRC tramp setting. details as following. but it did not work. can anyone give some help. thank you.
Matek F405wing with ardupilot 4.3 dev flashed
|SERIAL4_BAUD|4|
|SERIAL4_OPTIONS|4|
|SERIAL4_PROTOCOL|44| (37 is smart_audio, 44 is IRC tramp)
|VTX_MAX_POWER|800|
|VTX_OPTIONS|8|
|VTX_POWER|25|
Same here:
setting power works once, either manually from 0 to positive number, or on startup if been set to some positive number.
check this. see if it helps
