Integrating a Custom Sensor as DroneCAN Proximity Sensor in ArduPilot
Hello ArduPilot community,
I’m working on integrating a custom sensor into the ArduPilot stack using DroneCAN as a proximity sensor. My sensor is capable of communicating through CANFD. After studying the ArduPilot stack code and documentation, I’ve come to the following understanding, and I’d like to confirm if this is correct or if there’s a better approach:
  1. I need to customize the firmware of my sensor to match the DroneCAN message format for proximity sensors.
  2. Specifically, I believe I need to make my sensor output data that matches the format defined in: dronecan/libcanard/dsdlc_generated/ardupilot.equipment.proximity_sensor.Proximity.c
  3. By doing this, I should be able to directly integrate my sensor as a DroneCAN sensor in ArduPilot without modifying the ArduPilot codebase.
Is this understanding correct? Are there any additional steps or considerations I should be aware of?
Any help would be appreciated. @Yuri_Rage , @tridge , @siddharth @iampete.
Thank you.
Can anybody help me out on this please…?
Hello, I am also working on the same issue. As a result, did you complete the project successfully? If you completed it successfully, can you give detailed information privately or here?
Thank you.
Hi Karani,
I haven’t completed it,but still working out a way to figure it out.
Will update it here if i get any success…
