I couldn’t find much code that involves sending mavlink_led_control_t
and mavlink_msg_play_tune_t
messages and the comments / documentation on both isn’t too helpful.
I would like to know more about the message format, in particular, what to put in the following fields…
char tune[30]; /*< tune in board specific format*/
for mavlink_msg_play_tune
uint8_t instance; /*< Instance (LED instance to control or 255 for all LEDs)*/
uint8_t pattern; /*< Pattern (see LED_PATTERN_ENUM)*/
uint8_t custom_len; /*< Custom Byte Length*/
uint8_t custom_bytes[24]; /*< Custom Bytes*/`
for mavlink_msg_led_control
Additionally, what is the proper way of triggering a tune play or led change outside AP_Notify (e.g. say I wanted to play a certain tune and flash some LEDs whenever a particular message is received, should I call AP_Notify::handle_play_tune(&my_tune_msg);
EDIT: clarify question asked
