Hi all!
I use an orange cube on my helicopter. Arducopter firmware 4.3.6. Fly Dragon FLYD100 carbon frame. During the flight, I noticed that the drone was acting unstable. After analysis I noticed a significant increase in vibrations. The flight controller is located on a double-sided paralon. Will the software filter settings help in this case or do I need to install the flight controller on the vibration pad?
I can answer your 1st question. The notch filter will not fix a problem with inherently high vibration levels. Some application require an isolation mount for the cube.
