Incorrect graph display FFT
Hello everyone,
I’m setting up harmonic notch filter, and, while opening the log through the FFT option through CTRL-F in mission planner, with the parameter INS_LOG_BAT_MASK = 1 and INS_LOG_BAT_OPT= 4, the logs turned out to be “torn” (ACC2, GYR2), what could be the reason?
Incorrect LOG_BITMASK
What exactly is wrong?
Select “Magnitude” before loading the log into the FFT UI.
Then ignore the Accel graphs, focus on the Gyro graphs.
Really, it’s look correct, thank you )
Interesting, why sometimes without “Magnitude” the display is correct and not correct
