I might have started another imu temp. cal. accidentaly, do i just set INS_TCALx_ENABLE to 0??
No, you do all imus at once. And once completed they automatically set themselves back to 1.
If you do it manually, all hell breaks potentially loose. Don’t do it.
And stop accidentally starting imu calibration.
I was checking the parameter of previous steps in the M.C. and i might have pessed the “load params” button at the 02 step.then when i opened M.P. for a different job i saw that the 2 imus where doing temp. cal.
Since i have already done and the harware report shows it as succesful, should i do it again or something else?
Just select step 03 on the combobox, when asked, do not load a .bin
file and “press upload parameters” It will fully clear your mess up.
