I am building a rover using a Raspberry Pi 4 and Navio2 with ArduRover 4.0. I’ve connected a rain sensor to the Navio2 pins and can now read its status (1, 0) on the Raspberry Pi. I want the rover to respond based on the sensor’s status. For example, if the sensor detects rain, I would like to receive a warning on Mission Planner or activate the return-to-home feature. Is this possible?
If its just a binary output you can just use it as a button to activate an auxiliary function, if you want more complex behavour you will need to use LUA.
Also you should replace ArduRover 4.0 with Rover 4.5.1.
Thank you for the response. I tried using it as a button, but I couldn’t set it in Mission Planner. I changed BTN_ENABLE from 0 to 1, set BRD_PWM_COUNT from 8 to 12, and changed BTN_PIN1 from -1 to 55 (which should be the GPIO pin according to the Navio2 documentation). The problem is that the options BTN_OPTIONS1 and BTN_FUNC1 do not appear in the full parameter list on Mission Planner.
Unfortunately, the last version supported by Navio2 is 4.0
Thank you, I didn’t know that it was possible to update ArduPilot on Navio2. From here it seemed that it wasn’t: Upgrading | Navio2. But after your post, I found this page: Building from sources | Navio2, and even though it was a bit difficult, I managed to update the firmware. Now I will try again to set up the rain sensor. Thank you.
Awesome! You could have used the .bin from my link, BUT building from source is a great excercise
I didn’t realize there was already a completed file Next time I’ll use that one, thanks!
