andyp1per
(Andyp1per)
September 19, 2023, 7:39pm
43
I think this is just saying SBUS inversion could be a problem.
We don’t pull the pins high or low by default and there is no inversion HW on the Blitz because it is an F7 and doesn’t need it.
You could try changing the bootloader to pull the pins high specifically.
I am using the Matek ELRS RX but I have others that also work fine.
boris-gu
(Boris Gubanov)
October 8, 2023, 5:38pm
44
So, it looks like I’ve managed to solve this problem.
The ELRS site describes a similar problem, but since everything works as it should on betaflight, it must be FC firmware.
I found the line DEFAULTGPIO OUTPUT LOW PULLDOWN
in the hwdef-bl.dat file and assumed that if it was deleted it might help.
Here are the steps I followed. Perhaps it will help someone else:
Configured the Linux environment as described here
Find ardupilot/libraries/AP_HAL_ChibiOS/hwdef/BlitzF745AIO/hwdef-bl.dat file and commented out DEFAULTGPIO OUTPUT LOW PULLDOWN
line
Build a bootloader as described here . The required file should appear in ardupilot/build/BlitzF745AIO/bin
Uploat the resulting file to the FC as described here
I could be wrong in some ways because I reached this result about a week ago. But everything seems to be correct
andyp1per
(Andyp1per)
October 8, 2023, 8:19pm
45
Hi Boris, thanks for the sleuthing. Which pins did you have your ELRS receiver connected to? Sounds like pulling pins low on UARTs is a bad idea.
boris-gu
(Boris Gubanov)
October 9, 2023, 1:56pm
46
Initially I connected the receiver to all possible SERIAL ports, but none of them worked. After re-flashing the bootloader, I connected the receiver to SERIAL1
