If follow to arrow direction and when picture of arrow on top then works fine.
But I hate this board. because motor numbers are wrong. Like M1 from left side but should be from right side
If we assume that arrow should be from down side and motor mounts are right then
“Here is a firmware using the existing bmi270 which uses ROTATION_ROLL_180_YAW_135 - lets see what that looks like. Firmware is in the same place.” - must be rotated on 180 deg YAW
So this is with the latest firmware that I posted? That was 135 yaw only, so its basically 180 yaw out, so 315 should work. This video is with AHRS_ORIENTATION = 0?
Ok so the hwdef orientation is still wrong if you need that AHRS_ORIENTATION to get the correct behaviour. Ignore motor order for now its the board orientation that is important. So I guess we need to subtract one from the other. Here is Roll180Yaw315:
I tried this firmware. Yes , it went past the INS error unable to initialise driver. i am now having response on Baro, Acc and Gyro.
GPS is detected but the Compass is not detected. I am using a Foxeer M10Q-250 connected to Serial4=T4R4(indicated on the board)
Current issue:
*ELRS connected to Serial3. upon powering up the drone via battery, the green led indicator is instantly solid ON. The only way for me to connect my TX to the ELRS receiver is by doing this sequence.
Power up using battery (ELRS indicator is solid ON)
Connect USB on FC
Connect mission planner via usb serial
*Second issue, i have a Holybro SiK telemetry radio V3 connected on Serial7. Cannot establish Mavlink connection. This was working when i was using Betaflight firmware.
Betaflight: All functions are working before i switched to Ardupilot Firmware.
GPS + Compass = OK
ELRS = OK
Mavlink (SIK) = OK
Compass is not part of this version of firmware - you need to use custom build. But @andyp1per is it possible to enable compasses by default? I’ve recieved build with good size for that MCU
Sorry for not being clear.
The led indicator on elrs is usually blinking upon power on and waits for TX to connect to it.
But in this case, the elrs rx module’s led indicator is instantly solid ON (it never blinked) when battery powered.
So this version defines the UART pins on 3/4 and as output high in the bootloader - it might avoid the RX going into bootloader mode. Please try. You will need to flash the hex as you need the new bootloader.
