I’m assuming that the porting is somewhat complete at this point.
However, as I can see, there is no way to test it without the bootloader.
I have the board, but i wouldn’t like to make it “Ardupilot only” (AFAIK flashing the bootloader makes it very hard to return the board to the initial state and flash e.g. Betaflight afterwards).
Can someone orient me about whether it is possible to somehow flash without a bootloader, or at least orient what should happen for this and how long to wait for this?
I tend to disagree. During the porting process I was switching back and forth to betaflight .hex using the STM32 gui very easy
remember to boot in dfu mode and that’s it, you can re flash betaflight at any point
maybe im wrong but this is my experience
installing the ArduPilot bootloader is a one-way operation. You cannot restore the board to factory configuration or load betaflight after this step - you would have to return the board to Seriously Pro to be re-flashed with factory firmware, assuming that is possible
Further reading the documentation, I just realized that the section i was referring to is Seriously Pro specific. Therefore, there will be no problems with flashing bootloader on Blitz F7.
Totally. I will be using setup with multiple rangefinders and optic flow sensor, hope everything will work right out of the box. Will provide test results here and on Github.
First of all, I am very glad that this FC is finally fully supported, huge thanks to @Pol_De_Petris@andyp1per and other contributors.
I am able to flash and fly (some tuning is on the way).
However, there is a serious problem related to ELRS receiver.
When i power the copter, it forces the receiver to bootloader state.
Tried every available UART.
AFAIK, this somehow relates to the board circuitry and how it handles uart pins during setup. It can be somewhat easily solved by pulling the TX pin of the receiver to 3.3V with a resistor, but this FC doesn’t have any 3v3 outs!
Betaflight works OK btw. So this can be fixed with the software.
Any ideas?
Right now the only viable solution I could come up with is assembling receiver with a connector, disconnecting it, powering the copter, connecting the receiver. It’s not how I would like it to be, but I need this to work ASAP for my project where I need ELRS + Ardupilot combo.
Hardware: IFlight Blitz F7 AIO, Happymodel EP2 TCXO on UART1, Rush Tank Tiny on UART7, LED strip.
Thanks for a quick response!
This sounded promising, but unfortunately didn’t work
Tried both RX and TX, both pullup and pulldown
I mentioned that I managed to get it to work by disconnecting receiver, powering up, then connecting again.
However while testing different UARTs, I noticed that if the receiver is connected to UART3, it doesn’t power up from USB (UART1 does power up when I connect FC to PC via USB). So, when the receiver is connected to UART1, it gets to bootloader state regardless of whether it was powered by USB or battery. But when it is connected to UART3 for example, the following sequence can also make it work normally:
Connect USB
Connect to Mission Planner
Plug in the battery
Ofc this is not how it should be, just trying to provide maximum amount of info.
I have never heard of this problem before and I have never encountered it during my testing of ELRS, I think it must be a problem with your receiver. Many people are using ELRS with ardupilot without encountering this issue.
The problem seems to be persistent, I tried Happymodel EP2 and ELRS Lite Receiver.
And I repeat, just flashing Betaflight helps too, on both receivers.
